New member.
Hello, New member here. I've just moved to Portugal and are in the process of buying a Clio 200. There are only a handful of these cars here, so I am desperately needing help sourcing a good one. I prefer one with the “cup” option, but there seems to be a lot of disinformation coming from the sellers. I guess running the VIN on the Renault site should show the “cup” option if so equipped?
Any assistance would be greatly appreciated
Steven
Welcome. Are you aware of the differences between a real Cup and the ones with a Cup chassis?
True, a 200 cup and a 200 with cup pack isn't the same.
A 200 Cup will have a physical key to open the car that you can put in the ignition, this is the easiest way of telling. The interior will be relatively poverty spec in comparison - the dash will have a visible airbag cutout in the passenger side, manual mirrors, etc
A 200 with a Cup Pack will be harder to confirm. Usually red caliper's will denote a Cup packed car, but the best way of checking is to download the Renault app and enter the VIN, this will give you a full list of factory spec options.
I was not able to successfully find the Renault site where I could search by VIN and have the options for the car displayed...
In the UK there is a phone app called My Renault. If you put in the car registration it will tell you what the car spec was when it left the factory. I am not sure if the app works in a similar way in different countries.
A fairly quick way to see if it is a Cup or cup packed is to look at the external door strips. If they are plain black plastic the car is usually a Cup. If they are colour coded and the same colour as the paint work then it will usually be a full fat that could be cup packed. But, if you go and look at the car see if it has a physical key that you have to put in the ignition barrel and twist - that is definitely a Cup.
Cars are insanely expensive here in Portugal- I should have shipped my 991.2 GT3 here when I moved from the states last year for a 1 time exemption from IMT
A New Members 3
I New Members 1
Red Baguette New Members 7
OutlawAsh New Members 1
RhysThomass New Members 0
