Need a favour guys. Car height
Yiannis197
Can someone please measure the height of their cupped car from road to wheel arch? Obviously the car needs to be on a level surface, OEM tyre dimension etc.
Thanks in advance.
Yes mate my car was cupped and I'm now on AST coilovers, I lost my initial notes and I just want to see how much lower my car is at the moment:smile:
Sorri about late reply.
front from ground to wheel arch. 66cm
rear from ground to wheel arch. 66cm
mine a 2009 full fat with cup chassis stock ride height.
Thanks a lot mate, appreciate it.
Are you sure about the rear height? Because I know that our cars have higher rear end from stock. Have you got anything in the boot possibly?
I thought that. But I never go anywhere with stuff in my boot. I will double check tonite.
Just checked mine and I've got 65.5cm front and rear that's with 3/4 tank and a microfibre in the boot so could possibly have a higher rear if the tanks empty but can't imagine it being much higher, mines a full fat with cup pack :smile:
Thanks a lot guys. Quite interesting really, I'm sure the rear sits a bit higher on the OEM setup but I might be wrong...
I was running them at 625mm at the front and 640mm at the rear [MENTION=32]gaz[/MENTION]. Since then I raised the car a bit, equally each end but yet to measure it. I will and report back.
