if your fitting a cat back than yes, you have to cut the exhaust as the second cat is built into the mid section, you should have som bracket with the exhaust the connect your standard cat to the new system, if your decating then obviously the decat pipe will replace the your standard cat, either way you have to cut the exhaust to get it out. hopes this helps
