Luke_197
I haven't noticed a huge difference with mine going on first track day tomorrow so I may have a different view tomorrow night!
Let me know how you get on mate. I've been told on track they perform very well.
The best combination would be the disc rotor size of a rim, something like Buell XB12S has, and it has more or the same stopping power with the same sized caliper/pads than mine 2xBrembo Serie Oro radial calipers and dual 320mm rotors.
Why is that?
The bigger the rotors the better the heat dispersion/distribution is also.
Try to spin the wheel of a bike with your hand and stop it with the hand as near to the hub or as far to the tyre and see the results.
I find it ALWAYS easier to stop the bike wheel when grabbing onto the tyre.![]()
the guy has a point...my breaks got really good after just changing the pads...still would go for a bigger set up if i could though...went on track today and it was awesome! the brakes worked excellent with ds3000s in front and ds2500s in rear but to be honest I cant see a massive difference to the standard discs they where a little better obviously but the standard discs are already quite big so are very good so its very hard to tell the difference my advice to any one is stick with standard discs and just put a good set of pads in unless you like the look of them which I do
Do those omp tow straps fit on any car? Thinking about getting one to break up the front end a bit. Can't decide between a red omp one or a blue trs one. The car is racing blue
Luke Luke, you know my thoughts mate, get the Supersprint now!!!
As you also know, I've not had any issue with a flat spot since fitting mine mate....
