Longer Bolts for 20mm Spacers
20 mm longer than the current ones, Measure exsisting thread then + 20 mm
The pitch I don't know though
only thing with those bolts is head is 17mm as apposed to 19mm OEM
But its just a different socket spanner instead mate
pretty sure the original bolts have a thread lenght of 28mm iirc,i used 41mm bolts with my 16mm spacers and they fitted perfectly,wouldn't want to go any shorter tbh,i got them from larkspeed and they have 19mm heads,if you look under the car at the back of yr brake discs u can see how far the studs stick through,standards came through the threaded holes by a couple of mm's so you need to replicate that,i'd say u need know shorter than 45mm bolts,u can always cut them down as well if u can't get the perfect size
What locking nuts did you get along with the longer bolts? I've not been able to find a set to match the new bolts, can't find any long enough with the correct seating type.
got them from larkspeed as well,had to cut them down a fair bit though but they have the right seat,thread and a 19mm locking wheel nut key
