Locking wheel bolts help please
Hi
Does anyone know what angle the taper needs to be on the locking wheel bolts? As I need to get sone new ones.
I know from searching I need m12x1.5 but unsure on the collar taper angle.
Also with my standard alloys do I need to find some lockers with the connical washer or does it matter if there is no washer?
Any help is appreciated :smile:
Clio wheel bolt size:
Standard bolts are:
m14*1,5mm 60degree cone seat
27mm thread length
19mm head
Personally I wouldn't bother with locking nuts, they are more hassle than they are worth. Can't remember the last time I heard of a set of rims being stolen off a car.
Thanks for the info but...as my clio is a non sport I have 17mm heads on the bolts and by all accounts they're m12x1.5
Is it possible just to order standard bolts from renault? I assume it is...just wonder how much they'd be wanting for them :-/
The size will be as above to the same length as your wheel bolt that came with the spacer.
Get a tape out.
