I've seen a few people with the same steering issues on the forum so i thought i'd try help everyone out and make a progress thread on how i sorted it without it costing the price of a pair oc recaros, so here it goes;
A couple of months ago after a flee about some really tight corners on a back road my steering started knock when Turing the steering wheel 45 degrees. Although it doesn't effect the driving if the car it's still annoying. So I had a look as the steering and after a bit of inspection I found it was a worn bushing on the steering column (upper joint) so I had a look online and the local car breakers. No luck as standard clios have a different steering set-up. So I found this eBay store that specialises in Renault used parts called 'Renparts ltd' and after a couple of emails they found the exact part I was after and now I'm just waiting on delivery, I'll update with a vid of the steering later!
