just fitted KTR induction ki
fitted kit in between showers, take about an hour, battery box takes some removing.
no sound difference when reving engine , but once out on the road the sound is awesome.
There a good job No need to remap them after fitting even with a exhaust too only needs remapped if u want it , u will still see gains with out a map
ah i forgot you got your scorpion done last week!? How you finding it? Did you get it alligned properly?
Arrived and lined up perfect, only problem was the exhaust tips where different so they sent a replacement back section next day.
Sounds so much better than standard, lovely sound on tick over too. The induction kit still drowns it out at 5k RPM though :jump1:
my scorpion has started to melt my diffuser k-tec moved it now its wonky and moved back but the sound is spot on.
scorpion is a brilliant system but be aware that they do melt diffusers
Have you got any pics of what you did with the other intake was thinking of getting a ktec induction kit but was sure what you do with the butter fly valve/solenoid
