How many of you have HID lights ??
The base of my HID bulbs (where the metal clip holds it in place) is slightly wide and my bulbs have dropped down in the light unit. Basically pointing at the ground now!
Need to sort it asap!
Anyone else had this kind of problem?
Not had this but it sounds like it's potentially the wong bulb. I only say this because thehole for the bulb is bearly bigenoug as it is!!!
Do you know what bulbs the kit was for? Also what headlamps do you have, are they projectors?
the projectors look like a curved glass ball where the main light shines through. the reflectors are the bulb with glass behind it to reflect the light forward.
Fitted my HIDS today which is easy peasy!! bumper had to come off as you can see!! i used the "how to bumper off" guide on here, which was spot on.
Once the bumper was off it was very easy to fit the HIDs litterally plug and play! i didnt have to cut the clip tht holds the bulb in place just un hook it then put the bulb in and hook the clip back into place easy!
The results
The bulbs are 6000k for info
Any questions regarding the fitting of the HIDs just give me a pm
