footrest
is this the right parts number for this footrest?
0200308061
thanks
the footrest that you buy is actually the megane sport item.
will see if i can find you the part number.
there is also a backing plate but you dont need this as you just rivet it to the carpet.
Giles there is another thread somewhere with the part number. Use the search function that's what I used to find it last time.
Smiler, there s no need to drill.
You just make a hole in the carpet with a small screw driver.
lol so you just pop rivet to the carpet then jase? is that not a bit loose doing it that way then??
Mines been on 3 years and hasn't moved at all.
Everybody I know has just riveted them to the carpet too.
