Dodgy Start ups ???
Not sure where to post this but anyway...
It's when i start the car for the first time that day i set off no higher than 3000rpm through the change ups and literally after a mile it feels as if the car is juddering/braking itself ? not sure if anyone else has experienced this?
It's called kangerooing once it's warm it stops
Or turn T/C off for 5 mins and it will be fine
engines run very flat and weak when cold...very common issue with them renault recommend you let it warm up for a couple of minutes before driving off :001_rolleyes:
there is also a cold start ecu re-flash that can stop it
