Do Clio Cup race cars use spacers or different offset wheels...
If you see them here, the 17" speedlines seem to fill the arch just perfect.
do they use spacers on the cup cars or do they have "special" cup wheels with different offset.
Anyone who knows how much they are lowered???
The wheels come in two offsets IIRC both are further out than the standard et68
They are also 8" wide instead of the standard 7.5"
cup doesnt use spacers, cant get on partslist so cant tell what the part number is but imagine its camber shims not spacers?
cup wheels are 8" wide. suspension is same as normal car apart from coilover threaded units. car offset is the same.
it wont be camber shims, theyd make the wheel look like it sits in the wheel arch further.
id say its more likely to be a wider wheel with a lower offset or spacers
Wheels are 8x17"
Front has spacers bolted to front hubs.so the wheels dont rub on the strut,as the front uses lots of camber
Rear is determined by Camber/toe shims.
Outpace-Racing.co.uk
