Hi guys after a little bit of help I've searched through the forum but still can't find out if these spacers ive found will fit / or are the correct ones for my clio 200 cup the centre bore is correct at 60.1 but it doesn't say if its for my model. Also has anybody else fitted the same make are they the best I can get, I've read that you can get 25mm in with the standard alloys and also lower it without rubbing is this correct I'm currently running 215/45/17.
any help would be great cheers in advance
http://www.dcperformance.co.uk/cheap/779384/renault/h_r-trak^-wheel-spacers/5035601.html
