Clutch squeal?
So my clio has developed a squeal which is only really noticeable on Idle with windows down.
Seems to be coming from the clutch when it's all the way out. If you press the clutch in even if It's just a tiny bit....The noise disappears.
Is my clutch on the way out or can it be saved?
Sounds like the release bearing. Might as well do the clutch at the same as it'll need to come apart anyway.
