Clutch pedal notch
I've noticed recently, and more so yesterday when i did a long journey, that when i press the clutch pedal in that i feel a notch/knock through the pedal.
Its not everytime and it only seems to be when the engine is on.
It's starting to get a bit annoying, anyone else had a similar issue. if so what was it and how it get fixed?
Any help is welcome
ive been feeling the same thing, i thought it was the matt so i launched it in the back but no.... still does it, now i have a rattle sound :/
I *think* it's something to do with the pedal being able to move/sheer in an accident. I'm sure I've read something similar on here before, give it a search.
If the clutch isn't slipping and you're not having trouble getting gears then I wouldn't worry about it personally...
It wasnt the noise, just that you could feel it through the pedal
I sprayed some white greese on the joints etc and it hasnt done for the last 4 or so days so im hoping it just needed lubricating
its probably switch for the push start, its been brought up many times
