Clio R3 Crash
That was brutal anyone see the chaps phone at the end if you look at the start it is zip tied up quite well see why they check them for track days
Jesus, rather them than me....
Dont blame him having a little shouting moment, must be horrid being the passenger not doing anything. At least the drivers mind is concentrating on 'trying' to control the car
nasty accident and luckily they got away with it uninjured. If they can learn something out of this situation is to how to set the car up properly. Obviously they are running too low at the back and the smallest of the jumps (considerably smallest) was more than enough to massively unsettle the rear.
Bit of a sweeping statement that don't you think? That's a bump, not a jump in a point of already high suspension loading so regardless of set up it would still unsettle the car to some extent. Unfortunately with rallying you can't set the car up to be perfect for every stage so you often have to make compromises. If anything was at fault it's the notes, that's what you look out for on the recce and adjust the notes accordingly.
Bad times at 1:27
[video=youtube;S6tTETKVSwc]https://www.youtube.com/watch?v=S6tTETKVSwc&list=UUPDis9pjXuqyI7RYLJ-TTSA[/video]
