Clio OEM TPMS
luke197
Hi All,
Does anyone know if any of the Clio’s came with a TPMS. I’ve found OEM wheel pressure sensors and on Dialogys the TPMS computer it sits under the passenger seat.
Just wondered if anyone has ever looked it to fitting it and whether it would work. I’ve looked at the retrofit version, but would like to keep the OEM look inside.
Cheers Luke
Well after a little bit more research it looks like it was removed from the option list not long after the 197 was released. It never worked correctly, aftermarket it is then.
I have it in mine. It works fine but is expensive to maintain if valves go or you have 2 sets of wheels, this is the Renault system though it came with the car as an option.
Don't do it is my advice.
When this system is fitted, were are the warning lights for it?
Is it the car disply in centre of clocks?
Is that why the car outline looks like carlos fandango?
