Clio 197 has been holding back and feeling pretty sluggish lately, seems to make a lot of noise but doesn't really go anywhere. So...
Got it scanned at a local garage who said it had a couple of Dephaser related codes (won't tell me exactly what the codes were), so those were cleared and now i've got an OBD app for my phone i'm able to see that the car has now thrown a wobbly and has a permanent code showing, as soon as i clear it it comes back right away...
Fault Code: P0300 Random Multiple missfire detected
Doing some research it seems that that particular code ending in 00 means the missfire is hoping between cylinders randomly so taking info from here (LINK)i've compiled a list of things that need looking at, this is where you lot come in...
1. Faulty Spark Plugs Or Wires Will order new plugs but untill then i've had a quick look at the wires and plugs around the tops of the coil packs and all seems OK. Anything else i can do here? (unsure if a faulty plug would cause missfires across all cylinders, unless ALL plugs have gone faulty at the same time?)
2. Faulty Coil Pack Any way to diagnose this?
3. Faulty Oxygen Sensors Which sensors is this referring to, and how do i check if they are OK?
4. Faulty Fuel Injectors How can i diagnose this?
5. Burned Exhaust Valve What is this, and how can it be checked?
6. Faulty Catalytic Convertor How can this be checked, and could it cause missfires?
7. Stuck/Blocked EGR valve Where is this on the Clio, and what am i looking for here, choked up and blockages?
8. Faulty Camshaft Position Sensor Have taken this out and had a quick look but cant really see much. Short of replacing it how can this be diagnosed?
9. Air Leaks/Un metered Air Where can i look for leaks? My noise trumpet has been removed and the vac pipe has been blocked securely (actual solenoid valve is still electrically connected, as you would when fitting an aftermarket intake)
Any info on any of the above would be greatly appreciated as this car is really starting to hack me off now, not had it long and it seems full of problems! Car is having a cambelt and dephaser pulley fitted in the next 2 weeks so maybe the new pulley will help?
