have you set it to max fan and to blow directly at your face? I've found climate control does not seem to be all that cold but if I change the direction of fan its cold.. however the CC does indeed cool the car down even if not blown directly at you.. Don't forget that the sun on your skin will make you feel warmer than it is even if you have climate control on..
The other thing is it may need a regas if its not been used all winter??
