cat200 on original exhaust?
hi mates, anyone has try to put a 100/200 cell on the standard central exhaust??
here in italy, we think it is the better solution... we think that for change/remove central exhaust or cat we need to make a lot of work on the engine.
personaly i think that exhaust line on 197/200 is very good, on the contrary the induction is bad...
next my step it will be re-fit original central and try this configuration8)
Hello pal, not worth it IMO!! STD cat is very good!!
Also the induction is better than you would think!! I fitted my new carbon one last night, will update with results asap!
i've already the 200cat on ktr exhaust.. i'm thinking to re-fit only the central part of exhaust and keep the terminal ktr...or you advise me to re-fit also the STD cat and keep so all STD exhaust except the terminal ktr? (only for less weight and best noise):biggrin:
last sunday i make a test in 3° and 4° gear @3000rpm vs an original r27 and a 200, i win but with a liiiiiiiiiiiittle gap!! too little for the money that i spent!
