Black Projector Headlights
Hi guys,
Karl is doing the projector lights at £330 currently which is a bit steep compared to eBay and when they were previously done by him at £230. Has anyone had any luck with a cheaper pair off eBay or somewhere else? Obviously not a genuine part but does the job all the same.
Cheers!!
FK automotive do projectors for the clio, obviously non genuin renault, but are really cheap, cant comment on the fit thou.
Cheers guys! Easy enough to swap the lights over? Guessing it should be pretty much plug and play?
Lights are well easy to remove. You get used to it when you need to change a bulb lol
you might have to change the plastic shoulder that the bumper sits on and the light leveling motor
