Battery relocation and wire tidying/removal
Flyingfish
Hi,
I'm looking to do the popular battery relocation and have looked at a lot of threads. It seems a lot of people move the relay and fuse holders that were on the battery tray. But I'm looking at other options. There are 2 micro relays in the power feed fuse board (777) which are listed as headlight washer pump relays. We model does not have these so I just wanted to check if cars came with a fully populated loom and as these were not needed could be removed from the loom.
Relays A and B are what I'm referring to:
The only reason I ask is that this diagram also shows there should be a fuse in position 4 and mine is in position 1. as the car is currently powered down I can't check much!
Thanks for any help
