Amp/tuner
Does anyone know how to get in to the amp/tuner under the drivers seat?
I have taken the front of the outer casing off but now it looks like the front of the actual amp itself needs to be removed. I assume it has something to do with the 4holes but can't see if they a screws or not.
Pull the plastic cover off the front (which it sounds like you have done), then the tuner comes out using stereo removal tools, just the standard 4 hole jobbies.
What is your prob?
Cheers. I'm going to need radio keys then. I need to have a look and see if there is an aux input in there. Looking to wire my ipod in.
You need to hard wire it, I may have put something in my project thread.
One of the plugs has four pins that represent L+, L-, R+ and R-, get a CD-ROM audio cable and chop it up for the sockets, fit then into the plug and bingo. Probably not a great explanation, I will try to explain better later.
Cheers. Just got some radio keys off eBay to take a look. I've been in contact with a guy on eBay and he's been really helpful, he has a wiring kit etc I just need to find out what's in the amp. I'm useless at audio stuff so not going to attempt to make my own lead.
