200 projector light retro fit
Rick
Gold Member
Hi Guys,
So I'm looking to upgrade my standard reflector headlight units to projector units (plus HID) for that crisp white glow.
Does anyone know if this is a straight swap when it comes to wiring connections etc/has anyone done this?
I realise the car will not be able to support the cornering light function but i don't have that now so can't really miss what you never had.
:thumbsup:
Any help and insight will be much appreciated.
Rick
Should be a straight fit, and if the car's cornering lights worked now, they would work in the projectors. Everything goes into its place.
Cheers, I don't have cornering lights currently so i don't think they will work but if the units still just plug in the same with no wiring changes required sounds good.
I did it - plug and play but you have to remove a riveted bracket from your old lamps and fit them to the new ones. Don't forget to move the leveling motors over too - they just pop off and on.
