197 rear springs
jack it up and put axle stands under the jacking points
remove wheels
place jack under one side of the suspension and support the arm
remove lower damper bolt
lower jack from suspension arm
repeat on other side but as you lower the jack just enough so the suspension
arm on the other side will lower enough to remove that spring - then remove
the spring on the side thats supported
dont leave the axle unsupported
and thats roughly how to do it
