Unfortunately I'm going through the same thing at the moment. The fuel rail doesn't have the usual screw on valve for testing. You have to remove the fuel line running to rail using the quick disconnect and connect a special Renault guage directly to the line. Fuel pump is then activated in the fuse box/relay box.
