Wheel alignment settings
harey
Winner - POTM November 2018
I’m having an mot done on Wednesday and thought whilst it’s there they could get the wheel alignment done.
The car was lowered on H&M springs a few weeks ago and have cup shocks.
What is the best set up for me?
Thanks in advance
Sent from my iPad using Tapatalk
Thanks in advance
You have no adjustability except for the front toe, I assume you have standard top mounts?
So just get as close to OEM (as when you lower the car on H&R springs which are quite low, it will naturally cause your car to camber).
If you fit adjustable front top mounts you can then sort out some camber.
The rear is a fixed axle, so only way you can adjust this is with shims.
So OEM will be fine mate.
Magic, thanks
Thanks in advance
guess where you do ya clothes shopping :tearsofjoy::tearsofjoy::tearsofjoy::tearsofjoy: didn't know they did lowering springs though...
