What to do next?
Hi guys,
Getting cambelt done, is there anything else I should get done whilst the engine's out?
List of stuff I'm getting done so far
New front subframe as it was corroded
New steering rack as it comes with the ball joints that i need and fancied upgrading to the 200 cup rack
driveshaft bearing getting replaced
and a few other small things such as cleaning throttle body
How are the flexis on the manifold? Might be worth getting some new springs too if they haven't broke already
Hi guys,
How much have you been quoted for new front subframe if you don't mind me asking?
Yeh I have thought of both of those things already, hoping the garage doesn't find anything untoward! I was thinking is it worth doing power flex bushings or anything?
I think the part was 140 but i can't really say about labour as I got quoted for the whole job, subframe was going to have to come off for the other bits anyway.
Reactions: Big Ben
I've got the lower engine mount and the gearbox mount on mine. I would 100% recommend them, reduced engine rocking and the gear change was much better too
Reactions: Dystant
Think I might have to do this also then! Cheers for the advice
