The H&Rs aren't as harsh as people make out! I have them and a lot of people found them a bit less harsh in the back of the car, probably due to being progressive springs on the both rear and front. (There is no end of complaining with the exhaust and stiff suspension combination
) But as for the geometry setup, there is really little they can do with the clios as the rear is fixed and the front hasn't got many adjustable parts other than castor and toe unless you get yourself a set of adjustable top mounts! Went to get a hunter full fast road alignment done and all they adjusted was the toe on the passenger side :s
