thats alright but most brake makers dont recommend you splitting the calipers!!
Surely I wouldn't need to split them just to do the piston seals? The pistons will come out without splitting won't they?
The pistons a currently free moving, and I wanted to get them powder coated at some point anyway. If I can get a seal kit I'll get them powder coated and put new seals in.
The seals on mine look like this, I never had any reason to think they should look different...brakes work fantastically!
What "Brake cleaner" was used?
Any kind of brake cleaner will do this! It's all the same stuff!!
Well it's more a clutch and brake cleaner. Great for lifting brake dust.
As I said its much safer to use soapy warm water and then for stubborn marks you can spray brake cleaner onto a cloth. These seals look like they've been soaked in the stuff!!
W | Tried to change the blower motor caused more dramas | Engine, Gearbox, Exhaust and Air Intake | 8 | |
G | HELP! TOYO manifold has caused massive misfiring! | Engine, Gearbox, Exhaust and Air Intake | 6 | |
Flat battery caused weird electrics | Interior and Audio | 2 |
