Weighty weighty clios
Right...
How heavy will this still be... I'm starting to guesstimate... anyone else have a 197 on a diet?
Full glass and metal panels
Original weight with "100kg" driver was 1290kg
Driver -35
Stripped interior with r019 rollcage
Stripped dash and matrix - 15
Race heater + 2
No AC comp or idlers -~ 4
Racer wheels - ??
2 fibre seats + 8
Stripped engine bay with carbon box and li batt - 30kg (so much crap came out!!)
Carbon scoop +.4kg
I reckon about 1200 with the driver @65kg and fuel
Circa 1100 minimal fuel & no driver is the target I think
That's +50 on top of a cup racer which also has metal panels and glass
Am I realistic?
Who has some scale shots?? :wink:
Can you post pic of the engine bay? You saved up to 30kg
Interesting:smile:
P.s originally 1240(official weight recorded iirc) is the ff non cup Clio or the naked cup Clio ?
I think @simoxmino weighed his and published the figure and what he'd done to achieve it.
Do i remember a statement banded around the net years ago saying something like:
Every 5kg of weight saved; is the same as having 1hp extra added (under acceleration) ?
More of us should look into weight saving TBH. Extra power is only really a help on the straight under full throttle.
Weight saving is a help everywhere......
Colin Chapman of Lotus said power makes you faster on the straights but subtracting weight makes you faster everywhere.
Reactions: sevenfourate
Interesting:smile:
Battery was 12 not 19 as I thought! Still lots of weight removed, old airbox and pipework is weighty enough!
I have to find simos weight.
I believe 1100 is a fair target!
@A1axx you thought about fibreglass panels? There's a company who make bonnet, boot lid, and doors. Has to be some good savings there.
Reactions: A1axx
After weighing that will be the next step, probably after next year! I would get them all at once when I can. MC racing would be who I would use, pound isn't strong enough at the moment mate .. wish I got them when I was collecting bits
So every 5kg I lose in body weight also, I gain an extra 1hp to my car? I best start running!
Reactions: Jimmy
Change the windows or even the rear 3 for polycarbonate.
Trim the inside out of tailgate and remove locks etc.
replace the massive twin pipe back box for a single box
Setup like an R3.
Are you still rocking electric windows? Was there a manual
Setup fitted to any Clio?
Was the cup racer built from a proper motorsport shell
Ie no extra brackets, no sound proofing, no seam sealer etc
Reactions: Lct
Setup like an R3.
Think the cup racers just don't have underseal and the brackets you normally trim not fitted in the first place
I have no locks mate. Most of he brackets gone. Yeap should trim the tail gate to lose a bit. Could change my milltek to single and run the centre res. I don't want it to go over noise limits.
Looks so much better with the tidied and stripped interior. All started up first time IMG_4943.JPG254ef6f9a68c436616ad361b3439f6b6.jpgddd6c0d26c5e93d26086126f8a9664ac.jpg
Setup like an R3.
im going on a diet!
Reactions: A1axx
Hi, where did you get carbon centre console from? Does it still give you access to key card slot and connector to allow diagnostics/remap?
Looks so much better with the tidied and stripped interior. All started up first time View attachment 15747254ef6f9a68c436616ad361b3439f6b6.jpgddd6c0d26c5e93d26086126f8a9664ac.jpg
