Traction control is not working ??
Hi all,
i have just taken my battery and airbox out and upon re-installing it everything woks fine apart from now my esp/ traction control says deactivated as soon as switch the engine on, could i have knocked a fuse or relay at all ? also when i press the button that usually de-activates it, it does nothing!
any help or advice would be much appreciated !
Thanks,
Directly after rolling roading or reconnection of the battery does this, drive it and it will go off.
Just needs to reset the ABS sensors, so as you drive it'll fix itself.
