torque steer?
mc200
When at motorway speeds, if I accelerate heavily the car pulls a little to the right, and then if I come off the throttle it twitches to the left a bit.
Its not a huge amount but requires a steering adjustment so I'd like to find out if it's normal or something I can fix, does anyone have similar?
someone mentioned it could be engine/ gearbox mounts?
Mike
Mike
Having the same issue here, but I was thinking maybe from my worn out semi slicks..
I'm interested to know from you when you fix it if it's from the ball joint.
