'The Silver Fox' Megane Trophy Progress blog.
Right probably time i started a blog.
Here goes.
Bought the megane back in septemeber, needing a cambelt, and injectors.
Looked like this after its first proper wash.
I did the cambelt and the injectors, and it ran much sweeter.
I then fitted a Forge Re-circ valve blanking plate, removed the foam in the airbox. to give it some wastegate chatter.
Next I fitted some mintex 1144 front brake pads and R26.R front discs.
and of course, a stage 1 remap.
Felt much better, more like a boosted car, now running just over 1 bar of boost.
As the weather started to get better i decided to pop a set of tyres on that I had been keeping by for a while.
my missus gave it a detail as it was very dirty from the winter. She did a full paint correction, etc.
Also took it to my mate stu <3 who chopped my back box out for me. and welded in a lovely straight pipe.
[video=youtube;ATw5S0_z2i0]http://www.youtube.com/watch?v=ATw5S0_z2i0[/video]
Next was time for an intercooler. So got hold of one, and fitted it, easier than i thought it would be. 40mins.
and now the intercooler has been done, time for stage 2.
now peaks at 1.5 bar, power was a bit disappointing, but by the time i had adjusted the new forge actuator, the air temp inside the dyno room was about 35 degrees.
so i will have to run it again when its cooler in there to get a better read on it.
So thats all for now. but i do have some more plans in the pipeline :smiley:
Your not selling now sam? You'll have to take me out in it again!! Think u should come on track with me at FCS!
i cant really afford to go on track at FCS mike. will need new tyres if i do :worried: ££££
its always for sale mate, everythings for sale if you get offered the right price......
Sounds immense, I wouldnt be too disppointed with the second dyno figures, ignoring the lower peak due to heat the power across the rest of the rev range is massively improved.
Makes me want a 225..
well it is for sale :tongueout:
and yeh im not too bothered by the second graph. it definitely has more power, you can feel it. will get it back on the rollers when i have a spare minute at work.
