Terence's Clio 197 Cup GW - Progress Blog
terencelyl7411
Greeting to you all in this forum, I'm Terence from Hong Kong.
Been getting this Clio 197 half year and I would like to share my daily maintenance / detailing stuff here.
Personal goal is to maintain the stock outlook and slightly enhance the performance.
I'm very satisfied with the power but the throttle response could be improved.
As for handling, the cup suspension is supporting well, i guess no change needed at this moment.
I'm also uploading photos & updates on my instagram: cu_898 <- please check that out and follow.
Apologize for any poor English up front.
Few pics to introduce:-
terencelyl7411
Gearbox refurbishment were done back in April 2020
Crunching sound were heard during 4 > 3 downshift, couldn't avoid no matter double clutching or whatsoever.
Bought a set of synchronizer for 3 & 4 gear for replacement
Start working
The garage broke my lower pivot so i bought the whole lower suspension arm.
And few days later the garage told me they need the synchonizer assembly (include the "gear gate lever?" too) so i need another purchase...
and finally everything done
Since all the Clio 3 in Hong Kong are imported, I have deep trouble on purchasing parts in Hong Kong.
No matter on searching parts number, buying parts, delivery cost, etc...
Keeping it running isn't very easy, only the above gearbox works costing me around 1500euro..
terencelyl7411
I recalled a guy's word: Renault is rattle, just stick with it / turn louder radio
and i'm not happy with it and starting to rectify it.
I start sticking velcro tape all around the interior
included A-pillar's edges, side mirror interior cover, centre radio display, centre console, glove box, instrument gauge trim and etc.
Sorry for not taking pictures for all places, let me know if you guys need any help on rectifying these.
I'm much happier after 3 weeks of sticking velcro and insulation tapes, the car are much more quiet now.
terencelyl7411
Somehow i'm bored and went to auto shop for a look.
and pop up with idea to clean up the throttle.
sounds great huh?
So i bought this Gunk throttle cleaner.
Dirt buildup around the butterfly valve (Red arrow)
After cleaning
A nightmare was happened after i sprayed and wiped, the engine can't start.
I turned the ignition for almost 3 sec, the starter keep running but it can't fire up the engine.
But finally i added few footstep to open the throttle and started the car, really scare my shxt out.
Since the throttle are facing upward, I think some of the cleaner may flowed into the engine and causing this.
But the throttle response was so much better after cleaning, especially on low rev.
I'm happy with this!
terencelyl7411
I bought a set of maintenance kit from ebay which includes air filter, cabin filter, oil filter, fuel filter and spark plugs.
Some photos when i replace the plugs.
107898217_1640043359482080_6439027384273017467_n.jpg 107897319_703653313522805_3597162514510262098_n.jpg
107920330_367727554195946_6436120022748664680_n.jpg 108993779_283430053106197_644783561389476817_n.jpg
Could anyone help? Why there are some rust on the plug 4?
I dont see any rust inside the plug hole / coil pack.
After all changing the new plugs improved a lot on low-rev torque!!
Cheers~
Reactions: wootwoot
suj
View attachment 141014 View attachment 141015
View attachment 141016 View attachment 141017
Cheers~
Have you numbered 1-4 from left to right? (Renault number them the opposite, 1 is right, 4 is left, so cylinder 1 is from the gearbox end).
Have a look at the washer jets, the pipework sits above that kind of area and can leak and allow water in which pools at the bottom of the sparkplug.
Reactions: terencelyl7411
terencelyl7411
I was numbering like this:-
107972718_1008707312881023_8688339984630840068_n.jpg 107920330_367727554195946_6436120022748664680_n.jpg
The one rusted is closest to the throttle one.
I checked the sprayer, no damage on it.
Reactions: suj
suj
Yes so Renault number them the opposite (for future reference).
Try putting some cardboard over the engine, close the bonnet and use the washers and see if it does spray out on top?
If no difference and still no leak, just monitor it, might be previous water that got in maybe?
O Clio 197 Area 6
M77MWw Gallery 2
Mossy Car Parts For Sale 1
Simon2189 Projects/Progress Threads 9
E New Members 4
