Switched live
Hey folks quick question. Is there a switched live in the engine bay anywhere or do I have to use one inside the cabin, ie radio or 12v socket
thanks for any help :smile:
Yeah I was sure I'd find something there but all the fuses are permanent lives and there are no connectors in the relay box just for the single relay that's already fitted, suppose I'll just have to run a lead through the bulkhead, I've noticed a massive grommet near the abs unit that should accommodate another wire :smile:
That's the gromet I Fed my Nitrous line through. Had to remove half the glove box and the airbox to get at it though.
Got a maxogen so airbox ain't a problem and I'm sure if I push enough cable through it'll show up in the footwell :smile:
Just by the passenger footwell under the glovebox there is an ignition live, I took my nitrous controller feed from there.
With the passenger door open, remove the rubber strip from around the front, remove the plastic and you'll see :smile:
Ignition live on a nut? What's it powering haha most ignition lives are small gauge haha and I've seen the earth point when changing the glovebox light, thanks anyway hopefully get onto it tomoro :smile:
image.jpgimage.jpgCan't find that switched live, you don't have a pic by any chance? There's a lot of cables in there but all the large ones are permanent lives :worried: This is what I can see with the glovebox removed (don't know why they've rotated)
