Subframe bolt sizes
Hi all.
I dont suppose any body knows the size of the bolts that go through the steering rack into the sub frame and the size of the bolts connecting the subframe to the lower suspension wishbone control arm link? Long story short them 2 bolts are cross threaded and I think there is a slight gap between the subframe and the steering rack mounting point which is causing a knock on acceleration. The bolts were removed and I realised they were cross threaded as I was having to remove the manifold. I have put on a pic to show where I'm talking about if my description was abit ropey. Then the next question would be does anybody no of these bolts available anywhere? Thank all in advance
Give me a should want numbers you want and I will get you part number and RRP and see if the bolt size is shown
