Stud and Nut compatibility
If you buy the correct fitting wheels then they are tapered the same as the originals.
TUV
Tapered collar screws M14x1.5, shank length. 28 mm, for type: M
Reactions: bedoef
Thanks PITA. I was a little worried there - I bought the ones advertised to fit the Clio. I realized they also sent me a set of wheel bolts at the time which I thought nothing of. But after reading about the nut taper, I was concerned. And Protrack have published they are closed until next year and I have a track day booked next week.
However Christian has come back and confirmed that the PMS kit will work, so all is well!
