197: Speedo needle removal?
Bro
Thought I would put this in the general chat as it applies to the 197 and 200.
I'm changing the LEDs in my speedo but before I go ripping off the speedo needles and messing something up has anyone removed them before?
Can't find any information on removing them for the mk3. Normally they just pull off but I thought I'd check first
You've probably figured it out by now but they do just pull off, takes a bit of courage!
I did figure it out in the end [emoji16]. I got two spoons and put them under the needle and used them to evenly pull them off
Good good. :smile: What colour are you changing the LEDs to? Be sure to post up a pic after...
I changed them to white. Maybe I should do a small write up of how to do it.
Couldn't find any information online of how to change them on the mk3 so just had to go for it
Reactions: Frank Perry
