Elviic
Hi All
I left my car on handbrake at work (had to pull it up fairly high) for about 8 hours. When I started driving, I realised that the left, rear wheel was stuck. The handbrake feels like it has snapped, there is absolutely no resistance when pulling it.
Had to stop in bloody Lidl car park. Tried pumping brakes, trying little stops to get the brakes off but no luck (looked like a right tosser). I poured some water on the brakes and they then started to slowly come off the disc, but they are still sticking, although not as bad....
I had to get home with starting and stopping as the rear left brake was sticking and smoking (only 5 min drive).
I assume that I will need to change rear pads, discs and the handbrake cable?
Am I correct?
Any help would be much appreciated.
Elvis
Am I correct?
Elvis
