Smallest wheels over brembos?
Alright people,
Just as the title says. What is the smallest wheels you can fit over 200 brembos?
Looking for something for track days.
I know I'm looking for 60.1mm bore, 45et and 5x108
Anything else that could possibly fit.
Can always get the tyre fitted to mount the weights on the inside of the rim. This is what I have to do to get my 17's to clear my 335 2 piece rotors.
Also looks better as you can't see the stuck on weights behind the spokes.
Reactions: Deelfc21
Some motorsport wheels are made to fit over big brakes so have more clearance in the middle of the wheel, it makes it harder to fit tyres as the dip on the inside is less shallow.
I had some 15" compomotive wheels on my Alfa that would clear 302mm discs and brembos but the standard Alfa wheel would not.
A 16" wheel like this might give the extra few mm needed to clear the brakes that the standard wheel does not have.
Reactions: DS197
16" tyres are typically more expensive then a more widely used 15 or 17" tyre, and you'll also have more choice with 17' tyres. I'd personally stick with the norm
Reactions: Deelfc21
