Scummy badges
Front one is bumper off and 2 torx bolts, not sure about the rear. Badge covers on ebay for £20.
I have a fairly good condition rear and possibly a front. Dont want alot for them if you are interested? Rear is very easy to change and front is a little harder.
no need for such drama :wink: front one has two torx in the back, but plenty of room if you undo the screws across the slam panel and ease it up about 6" to get an arm in with a torx bit in an angle driver or short stubby bit holder
rear is easier, however, for how long it takes id whip the boot plastic off and press the barbs on the 6 clips in from the inside so you don't break them, both were off in ten mins, fitting back is easy
I took mine off and keyed them up and gave them some satin black :smile:
EthanMenace Body Work and Exterior Lights 11
NikosRS Clio 200T Area 3
Alex Cockburn Clio General Chat 8
W Clio 197 Area 5
M19TNR Clio 200T Area 14
