Roof Bars For Clio 197
I've got a set of Thule bars on mine and the fixing kit works for all hatchback MK3s. Not sure about any other brands but I imagine its all the same - this is the specific Thule kit for MK3 Clios: Fitting Kit 3091
If it is Thule it should also be the 751 footpack, and mine has 108cm bars.
This site is also useful as it has a compatibility search and has other brands too.
Cheers Lewis - appreciate the response.
I will take a look at what you have recommended!
How easy are the to attach and detach? As the idea would be using them to load wheels onto for trackdays.
Interesting, I've thought about doing the same thing, how are you planning on mounting the wheels?
It's easy to fit and remove after the first installation, literally just a case of unbolting/bolting it up as I do the same for bikes and such.
I'd recommend replacing the plastic clips that prevent water getting into the threads on the rear mounting as the factory plastic clips are shite and broke when I tried to remove them. I just used some short nylon/plastic screws to keep the water out and leave them finger tight.
Reactions: Tarticmonkey
