Retro-fit RS Monitor
If it's just the data you want then you can get more from a bluetooth ODB reader and a cheap android device of some kind.
Everything from accurate MPG readings, A/F ratios and I would imagine boost pressures on the Meg engines.
Whilst that might be true, I think the Renaultsport monitor looks so good because it's part of the dash.
Does it require a particular radio to be installed? Cabasse?
Sorry but that look shocking imo.
Litchy you need to go down the 250/65 monitor route that actually as a use. As in throttle mapping.
only part of the clio monitor that is any use is the oil temp. FACT!
It would be if it was a measured value, but I believe it is a calculated value based on other measurements and an algorithm, so it's really not of that much use.
I have a RS monitor display that will be going in my 197 this winter, just for a bit of fun.
and thats just a calculation.....:chair:
I'm sorry but that looks horrific on that twingo, haha.
Lol, I agree. Makes it look like a taxi..
Wouldn't mind one in mine tho.
a few pages further along and it gets built in to the dash! :bat:
Sorry for hijacking thh thread but does anyone know if the 200/197 dash screen (not the RS monitor) is a straight swap? The reason I'm asking is because the 200 one has a better layout, it is updated etc. Apologies again..
So the Clio monitor is a pointless toy then......
@fox sorry didn't look further but now I know it's only an estimate on the oil temp I won't ever bother.
I love mine, it's just for fun. Love seeing how far off the G force I can hit it lol, use the 0-60 timer every now and then for a laugh
But if you can get it to throttle map then you find it far easier to drive in the snow.
Easy... Or fun? Mine will only go to a car park in the snow for play time other than that if we have any snow it will be rav4 time lol
Id rather have a scan gauge if i did not already have a rs monitor . . . even though i do a scan gauge would be my choice given your level of tune and required monitoring points .
