Phenom
Passenger side top mount has started knocking as cant afford the nice set of coilovers I want just going to replace the top mount with OEM part. I have two questions in my mind for this.
1. Do I need to do the offside top mount also?
2. As this is probably the first time the suspension will be taken apart since the previous owner put some lowering springs in, is there anything else I should replace at the same time? or bits that are going to be seized enough its easier to cut/drill them off and replace?
