Replacing Engine Mount/Rubber Bush?
Discussion in 'Engine, Gearbox, Exhaust and Air Intake' started by Rishi, Oct 24, 2016.
  1. Rishi
    Rishi Platinum Member
    598
    NWLDN
    Car:
    197 Cup Albi Blue
    I've had a knocking when cold from the top of my engine for a while now and found that the top mount (torque arm?) moves quite a bit when I wiggle it, searching the forum I see it's quite common.
    The arm itself looks easy enough to change, just 2 bolts, altho the way it moves I think it's just the rubber bushing that needs to be replaced. I see K-Tec sell them but are the bushes easy enough to switch over or do they need pressing out?
    Thanks for any info :smile:
  2. Pav
    Pav Moderator
    11,606
    Manchester
    Car:
    albi blue 197 with boost
    Rishi likes this.
  3. Rishi
    598
    NWLDN
    Car:
    197 Cup Albi Blue
    Thanks Pav, I'm pretty sure that's the same one I've ordered from K-Tec. :smile:
  4. Pav
    Pav Moderator
    11,606
    Manchester
    Car:
    ok..it will feel much better after you are done swapping..
    Rishi likes this.
  5. Rishi
    598
    NWLDN
    Car:
    197 Cup Albi Blue
    Thanks, that's good to know.
    I can't quite believe how much movement there is in the arm at the moment, I'm surprised it only knocks when cold. Makes me think maybe the other bushes are worth swapping out...
    tomwigan likes this.
  6. Pav
    Pav Moderator
    11,606
    Manchester
    Car:
    it wont hurt you,thats for sure..firm up the whole ride..like it :thumb:
  7. Rishi
    598
    NWLDN
    Car:
    197 Cup Albi Blue
    Any tips for getting the steel bush retaining plate off? Cheers
  8. Rishi
    598
    NWLDN
    Car:
    197 Cup Albi Blue
    All done just had to wack a screwdriver in there and it pops off!
  9. Pav
    Pav Moderator
    11,606
    Manchester
    Car:
    yeap..i got some chisels from a local pound shop...a screw driver works too..glad its done
  10. Rishi
    598
    NWLDN
    Car:
    197 Cup Albi Blue
    I can't believe how different it feels, much tighter in general, altho there is quite a lot more vibration, especially through the steering wheel when idling. It def feels better when driving though and the car isnt for sitting around idling :wink:
  11. Pav
    Pav Moderator
    11,606
    Manchester
    Car:
    the vibrations will settle down in time..mine are gone now after a few months of driving..
  12. Big Ben
    5,425
    Herts
    Car:
    197
    Hardly notice mine now mate. Won't be an issue!
  13. sevenfourate
    sevenfourate Devotee of OCD Paid Member
    8,437
    Lowestoft, England.
    Car:
    Citroen C2 GT
    If they are Yellow series bushes - they will rattle you a bit at first (Idling - especially with air-con on) but will loosen up a bit after 500+ miles - and like Ben said: You'll hardly even notice after that.
  14. Rishi
    598
    NWLDN
    Car:
    197 Cup Albi Blue
    Thanks for the heads up guys, I was thinking maybe it would be best to replace with an OE torque arm, as maybe the vibration isn't going to do the car good in the long term, so good to know it should settle down.
    Right now the car feels great to drive, very tight and no knocks or clunks.
  15. Sean197
    Sean197 RIP Albi :( Moderator
    3,485
    Fife, Scotland
    Car:
    Albi 197T - RIP, MK7 Golf GTD Sports Wagon
    If you think the torque mount bush vibrates, then don't fit the Powerflex upper engine mount, it vibrates like a ****.
    licenuk likes this.
  16. Dystant
    Dystant Detailing Dale Paid Member
    1,577
    Manchester
    Car:
    Clio 200 CUP
    Sorry to bump an old thread, and apologies if this is a stupid question, but does the engine need to be supported from underneath when fitting this?
  17. Pav
    Pav Moderator
    11,606
    Manchester
    Car:
    no mate..
    Dystant likes this.
  18. Dystant
    1,577
    Manchester
    Car:
    Clio 200 CUP
    Like I said stupid question! But better safe than sorry :tongueout:
  19. Rishi
    598
    NWLDN
    Car:
    197 Cup Albi Blue
    A lil update on this... after changing to the powerflex mount my steering vibrated when idling and with the warmer weather recently I noticed with the A/C on it vibrated a lot. It didn't seem to settle much even after 1k miles and felt all this vibration can't be good long-term so decided to fork out for a new OEM mount and the car handles much better now I feel. The last few months my car just hasn't felt stable and lost confidence behind the wheel but now it's back to it's original chuckable, sublime nature. The only other bits I changed this weekend was the n/s upper/ARB link-arm from Eurocarparts to the OEM and the oil/filter.
  20. suj
    suj Paid Member
    748
    Birmingham / Warwick
    Car:
    Nimbus Grey 197
    Was it the upper torque arm you changed to OEM?
    Mine does exactly the same (vibration at idle + with AC on when hot), it's annoying as hell!
  • Share This Page
