Removing interior trim..
Anyone got an idea of how I can remove the interior trim?
I want to remove;
Door handles
Radio clock cover
Window control cover on driver side door
Inside wing mirror trim
All air vents
Any advice would be much appreciated.
French = pull hard and it comes off.
Air vents should come out easily if you gently prise them out. I use a screwdriver or two to get behind them - the soft touch dash helps, as it doesn't leave any marks or scratch.
The wing mirror trim literally just pulls off into the car and the clock surround has 4 clips (pretty much in each corner), so again just prise it off gently. The clips are strong and shouldn't break.
theres a few items held on with tx20/40 screws etc and as said others are just clipped in to position
