Recaros
Only difference is the material, everything else will fit. Dead easy job also.
Presume your fitting 197 Recaro's into a 200 that previously had no Recaro's ?
197 Recaro's into my 200 fitted fine physically; as expected and done by so many others.
However - the wiring loom connectors / wiring colours on the 197 were like none i'd ever seen pictured (After preparing / researching; and having 3.3ohm resistors ready to get the dashboard airbag light out that accompanies this seat swap) and weren't really close to mating up to the 200 loom straight off. The appropriate connections couldn't easily / simply be bridged using the resistors and i personally didn't want to start hacking around the wiring too much after taking some advice.
So i ended up getting the light disabled via clip. Which was / is a far more professional way of doing it anyway; if you have access or are able.
Hopefully you'll have a more straightforward swap !
Swapped over my yellow dot recaros in the 200 to grey dot 197's and exactly the same fit - dead simple.
