Rear seat belt removal.
I tried this last night thinking it was just a simple task, but from what I can tell, you need to strip the entire rear of the car?
Is there a better way of removing them that's eluding me?
Thanks!
Afraid not..gotta remove the side trims under the parcel shelf to get to them..and the the ones above it too..bit of a fiddly job but hey ho..since you mind is set to do it,nothing will stop you right?:uk:
Afraid not..gotta remove the side trims under the parcel shelf to get to them..and the the ones above it too..bit of a fiddly hob but hey go..since you mind is set to do it,nothing will stop you right?:uk:
Ah. Annoying! Thanks
I'll have a go later and enjoy lacerating my fingers on the plastics. Why do Renault insist trims sharp enough to cut steel?!
Not of the rear, no. Sorry mate.
I have some of the front/front seatbelt setup but that's it.
Once the rear cards are off the C pillars just clip out and pull away from the roof lining too.
