Rear High Pitched Squeak (Video Inside)
Hi all,
This squeak has developed, only tends to do it at low speed and mostly over uneven surfaces although can do it over normal roads.
I have the KTR cutback which makes me think it might not be aligned properly or the heat shield is hitting.
Link to FB Video (Around 11 seconds in when i'm indicating)
Any thoughts?
It could be the rear brakes binding. Hard to hear in that video. I know it's an issue with the Clio 197 /200s as I had mine squealing like a total...... When I was at the 'Ring a few weeks ago. Try whipping of the rear wheels and then the calipers (2 X 13mm bolts) and checking the rear pads. Mine were totally seized and binding though it was much worse at low speeds.
